3/4 ton rear end in half ton truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2010, 08:52 PM
So ive found a rearend that i'm wanting to get for me truck. 1975 scottsdale 10. So from what i understand tahts a half ton truck. It has a 12 bolt rear end with five bolt axles. I'm wondering if this rearend ive found from a 1973 3/4 ton will bolt in. Also doesnt it have six bolt axles? can i swap mine out or are the axles different? thanks for the help guys
Old 10-24-2010, 11:03 PM
Hi
3/4 ton trucks came with 3 axles 14 bolt 8 lug full floater, 14 bolt 8 lug semi floater light 3/4 and 14bolt 6lug heavy half ton , they will all bolt on may have to move spring perches depending on year they came off of, I do not think your 5 lug axle shafts will inter change.
Old 10-24-2010, 11:50 PM
mud.man.rj's Avatar
axles
No way will the axles interchange only 5 and 6 bolt will interchange 5 is 2wd and 6 is 4wd 1/2 tons. 3/4 ton won't with 1/2 tons.
Old 10-25-2010, 06:30 PM
darn i don't like it when you guys give me bad news but from the research ive been doing i came to the same conclusion. So i guess ill keep looking/ Sad day, it was only gonna cost 50 bucks but with the u bolts not fitting and needing 8 lug rims it completely blows it lol
tranny and rear end combo for 1985 Dodge Ram street truck southernratchet1 Transmission - Rearend 0 04-27-2010 03:24 PM
1979 Chevy truck 3/4 ton 2 WD annoying vibrations. markzepp820 Transmission - Rearend 14 03-16-2010 06:34 PM
12 bolt (truck rear end) questions Dylanic_350 Transmission - Rearend 4 02-11-2009 07:52 PM
75 dodge half ton posi rear end 81elcamino Transmission - Rearend 0 10-26-2003 03:33 PM
transmission rear end for 65 chevy truck shortwide65 Transmission - Rearend 0 05-28-2002 09:37 AM
