3.42 1st gear and 3.70 rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2007, 04:44 PM
a borg warner super t10 with a first gear of 3.42 can I use a 3.70 rearend, it is going in a 56 chevy, thank you for the help retired 56 also it has a 355 in it
Old 11-21-2007, 05:56 PM
Marcel
Last journal entry: Choo-choo town
t 10
I ran 1 back in the 6 t's in a 57 327 and it was great. 4.11 was stock 4 55,56, and 57 stick shifts automatics were 373 anyway. It want do much for your gas mileage.
Old 11-21-2007, 07:08 PM
302 Z28's Avatar
That sure is news to me as we use to seek out 6 cyinder standards in the wrecking yards because they had 3:70's in them. I don't ever recall running across a 55, 56, or 57 with a 4:11 OEM.
Vince
Old 11-21-2007, 09:26 PM
Marcel
axle ratios
I would think that most of the 55,56 and 57 rearend were probably ripped out and replaced with 3.73, 3.56, and even 3.36's, the chunks would inter change up until 64. Best I can remember, my 64 Impala conv. 400hp 409 4 speed can from the factory with a 3.73 prostration. I do remember, if you power shifted it to 2nd, it'd rip the spider gears out of it. I think when I let it go it have a 3.36 tho.
Old 11-21-2007, 09:50 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
64 Impala gear options were 3.08, 3.36, 3.55, 3.70, 4.11, 4.56
Old 11-22-2007, 07:35 AM
302 Z28's Avatar
Correct, the 3:73 and 4:10 ratios came along later in the integral axles.
Vince
Old 11-22-2007, 11:08 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I think it will work nice!
Old 11-22-2007, 11:56 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Here is a gear ratio calculator.
www.grimmjeeper.com/gears.html
Take care,
rich
Ford 9" gear id. Jared Transmission - Rearend 4 06-07-2004 01:47 PM
3.70 rear end gear change lori-due Transmission - Rearend 3 12-28-2002 08:25 PM
