3.42 vs 4.56 and gear vendor o/d - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 07:02 PM
my current setup is a 454 th400 4.56 rear gears,help me decide if overdrive is needed for my app,3/4 ton 84 chevy pickup .with my gears now im runnin about 3100 rpm at 65 mph ,if i swap out to 3.42 s my rpm at 65 mph will drop to around 2300 rpm ,but if i keep the 4.56 s and add a gear vendor overdrive ill be at 2400rpm at 65 mph ,i like the 3.42s better lower rpm and more money in my pocket.but is there something else about having overdrive besides the drop in rpms?my truck will be used to tow my trailer and to be driven to work some time.all replies appreciated thanx
Old 04-22-2011, 07:35 PM
302 Z28's Avatar
You have much more flexibility with the Gear Vendors unit.
Vince
Old 04-22-2011, 08:08 PM
Vince
I dont get it can u please explain
Old 04-22-2011, 08:21 PM
Vince
Old 04-22-2011, 08:33 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
How tall are your tires? Must be pretty tall to spin only 2400 RPM at 65 mph with only a .78 overdrive ratio.
Old 04-23-2011, 06:56 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
With a Gear Vendors unit you can turn that 3 speed trans into a 6 speed. The unit can be used to split gears for less rpm drop between gears.
There are examples on their site, scroll down the page about a third of the way: http://www.gearvendors.com/hrgm3s.html
Old 04-23-2011, 09:19 AM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
Vince
^^^^^^^ x2
this gets my vote if you do some towing
gear vendor OD for TH 350 Steve Vento Transmission - Rearend 3 05-09-2007 12:29 AM
gear vendor ????? FIRECHICKEN195 Transmission - Rearend 3 04-18-2007 08:09 AM
Gear Vendor George Hendricks Transmission - Rearend 13 08-23-2006 09:59 PM
Gear Vendor juiced66malibu Transmission - Rearend 1 05-13-2006 12:16 PM
gear vendor unit bailey40ford Transmission - Rearend 3 06-02-2003 11:16 PM
