3.4l gm v-6
I'm looking at 2003 3.4l vehicle purchase. How common are intake gasket problems?
| The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post: | ||
vinniekq2 (01-21-2013) | ||
I see a lot of them. 50 -60 K on intakes, and if it overheats as a result, youll be doing head gaskets, and both at 100K .
See it all the time. There are TSb s for the intake bolts, they want you to use the GM bolts that have a pre cured thread lock agent. As long as you put blue lock tite on the center bolts and red on the end bolts , you will be OK. Also torquing them proper is critical. More is not better, to much torque stresses the frame around the eurathane beads that make the seal in the gasket , the frames crack and pre maturely leak as a result.
Fact is stranger than Fiction |
| The Following User Says Thank You to LATECH For This Useful Post: | ||
