Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3.4L V6 Firebird loosing coolant... Where?
Old 03-23-2012, 01:09 PM
maverickmechanic13's Avatar
maverickmechanic13 maverickmechanic13 is offline
I'll have a beer with that.
Last journal entry: My Trans Am
I have a 1995 Firebird with the 3.4L V6 engine. Car runs and drives fine... However - it looses coolant; but where is it going?
There are no apperent leaks, or puddles on the ground if the car is kept in place, ran and warmed up. Yet, if its driven it slowly looses coolant. The previous owner dumped a healthy amount of sealer in the system, which in my opinion is not a repair. The motor oil is not milky at all and there is no white smoke coming out the tailpipe. The oil fill cap and the valves (as can be seen through the valve cover are clean - not milky). I know these engines are very prone to blowing intake and head gaskets.
I haven't done a compression test, a leak-down test or a radiator pressure test yet. Am i missing something? Does anyone have any input or ideeas?
Thank you.
