Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3.70 or 3.90 with a t5 trans x 235 motor
Old 10-04-2012, 11:04 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
what RPM does the 6 rev up to when acellerating under full power? what size are your rear tires? Does the engine make fair power? or is the engine close to stock? a slow revving engine with low horse power uses torque to accelerate and using to much gear wont help as you will be shifting more than you should be.
