Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3.70 or 3.90 with a t5 trans x 235 motor
Old 10-04-2012, 10:52 PM
getset getset is offline
Originally Posted by vinniekq2 View Post
what RPM does the 6 rev up to when acellerating under full power? what size are your rear tires? Does the engine make fair power? or is the engine close to stock? a slow revving engine with low horse power uses torque to accelerate and using to much gear wont help as you will be shifting more than you should be.
The engine is mostly stock. I'm not sure about the RPM's under full power, but it maxes out at about 65 mph right now. My friend was warning me about having to shift too much, as well. Thanks for the information. I'm just getting into this, so don't know too much about it all.
