Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3.8 - 4.3
Thread: 3.8 - 4.3
Old 01-13-2012, 09:09 AM
rusty rockerpanels rusty rockerpanels is offline
star wheel
the star wheel (magnetic pick up assembly) I put in the distributor came out of a straight 6 (250) and is even fire. My primary concern is with the balance. The 262 had a stick shift flywheel, as I am using a 350 turbo tranny I used the flex plate from the 229. The question is whether it is a balanced assembly or independently balanced ? ALSO if it is a balanced assembly can this be fixed by changing the harmonic balancer ? HELP PLEASE
IF YOU CAN CONCEIVE IT, YOU CAN ACHIEVE IT
