We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 08-19-2008, 06:31 PM
KA67_72's Avatar
KA67_72 KA67_72 is offline
3.8 Chrylser Ignition Timing
I'm working on a 98 Caravan with a 3.8. Driving it with a scan tool hooked to it, the ignition timing is going nuts under moderate to heavy loads. The timing is momentarily dropping down to 7-14 degrees. It will do this from off idle to 5K. If you let off the throttle it goes back to 30+ degrees. It's giving no codes. Numbers from the Map, TPS, O2, and knock sensors look normal. What do you guys think?
Thanks,
Kevin
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "3.8 Chrylser Ignition Timing"
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
SBC Ignition Timing MarcoG Engine 15 04-09-2008 04:52 PM
3.8 buick timing eratic nomaddaddy Engine 3 02-29-2008 09:29 AM
305 ignition timing issues SS-10guy1983 Electrical 3 02-08-2008 05:05 PM
Ignition timing, Jeep 4.0 ChevelleSS_LS6 Engine 0 10-26-2006 06:20 PM
