3/8" female to male flex line needed. Any cars front wheel cylinder frame line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2008, 11:57 AM
Ripped's Avatar
Last journal entry: First RoadCourse Video
Hey guys. I am rigging up a hydraulic clutch line for my 'stang. The wilwood master and pull slave use a 3/8 - 24 inverted flare fitting on both ends.
I am going to bend a hard line to run from the firewall down to beside the bellhousing/toploader where the pull slave will be located. There must be a car that has a female to male 3/8- 24 flex line similar to what would be used on front disc or drum brakes (likely drums)
The front disc brake hose I have is 3/8" female to a banjo fitting. All I would need is the same type of hose ending in a 3/8 male inverted flare.
I need a flex line 10" - 16" long
Pull slave i am using
Master cylinder I am using
Thanks for any help.
Old 03-12-2008, 01:13 PM
You could also get a female inverted flare to AN-3 adapter, a pipe thread to AN-3 adapter (and remove the adapter on the slave already), and a prefabbed AN-3 flex line. Should be available at any speed shop.
...or just go to a GOOD parts store and see what they have. Front drum brake flex line sounds like a good start to me. Something like this from a '68 Impala maybe?...but it doesn't list the fitting sizes.
http://www.napaonline.com/MasterPage...e+Hose+-+Front
Old 03-12-2008, 03:47 PM
Ripped's Avatar
Thanks Triaged
I tried a couple parts stores, third time lucky I actually got someone who would look something up.
Anyway for future reference BH36744 is what I ended up getting
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
Routing Front Brake Flex Lines steve392 Suspension - Brakes - Steering 3 12-22-2007 03:28 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
Body Line Man586 Body - Exterior 6 08-20-2004 09:24 AM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 04:38 PM
