Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3/8" female to male flex line needed. Any cars front wheel cylinder frame line?
Old 03-12-2008, 11:57 AM
Ripped's Avatar
Ripped Ripped is offline
Last journal entry: First RoadCourse Video
Hey guys. I am rigging up a hydraulic clutch line for my 'stang. The wilwood master and pull slave use a 3/8 - 24 inverted flare fitting on both ends.
I am going to bend a hard line to run from the firewall down to beside the bellhousing/toploader where the pull slave will be located. There must be a car that has a female to male 3/8- 24 flex line similar to what would be used on front disc or drum brakes (likely drums)
The front disc brake hose I have is 3/8" female to a banjo fitting. All I would need is the same type of hose ending in a 3/8 male inverted flare.
I need a flex line 10" - 16" long
Pull slave i am using
Master cylinder I am using
Thanks for any help.
