3.8 GM into Ford Falcon? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 10:35 AM
Old Fool's Avatar
Has anyone seen or have experiance with a GM 3.8 into a early Ford Falcon or Mustang?
Old 10-22-2011, 08:09 PM
No, and WHY would you want to?!
6sally6
NM
Old 10-23-2011, 12:01 AM
JeffB's Avatar
I saw a '63 Fairlane with a Ford 3.8 T-Bird turbo motor,nice fit.
Old 10-23-2011, 05:37 AM
Old Fool's Avatar
Originally Posted by 6sally6
6sally6
NM
Fords 3.8 is a known for head warping gasket blowing failures. It also isn't as easy on fuel as the Buick 3.8.
Old 10-23-2011, 05:53 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Neither engine was a great one untill you get to the stage 3 buick.If it were my falcon I would find a SB ford to put in it. If you really want economy and not to worried bout 1/4 mile acceleration, then get a 2.3 (ford) and a manual trans and work it over a little. They are pretty simple engines and parts are still readily available.
Old 10-23-2011, 02:37 PM
Old Fool's Avatar
An automatic trans is paramount to this build, as is an economical to run engine, and cheap to insure.
No v8's for this build, no turbos, etc. Just a daily driver for a handicapped 16 year old girl to drive.
My parents had an late 80's Buick LeSabre with the 3.8 v6.
It had decent power for the size and intent of the vehicle.
Fuel economy was low 30's hiway.
Old 10-23-2011, 03:05 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
How about going with EFI? You could probably use the entire drive train from a 3.0L Ranger. It'd make decent power and get good economy.
Old 10-23-2011, 04:28 PM
LATECH's Avatar
A 2.3 automatic from a mustang or fairmont would be a good choice.
The buick would be OK as would the ford 3.8.
I guess it is whatever you have to run that dictates what you run.Or am I wrong?Are you looking for a motor to buy?Does the car have an engine in it?
Old 10-25-2011, 07:03 AM
Old Fool's Avatar
The car will be receiving a modern efi engine and od trans.
I am curious about the possible fitment problems with the Buick engine into the Falcon engine compartment.
Width of engine, oil pan sump location problems, engine height problems?
Once a plan of attack is decided on then I will purchase a donor vehicle to provide the drive train.
If I decide to use the GM 3.8 I plan on finding a 90's F-body for a donor.
If I decide to use a Ford 3.8 I plan on finding a mid-late 90's Mustang donor.
Old 11-01-2011, 03:57 AM
willowbilly3's Avatar
Last journal entry: Body mods
What about an efi Ford 4.0? They are great engines and good on fuel. Plus they are easy to find. I know you said a V8 was out but the Ford 4.6 Mod engine is also a great engine. I average high 20s for milage on my big Mercury with a 4.6. They are easy to find and cheap.
65 Ford Falcon falconfan Transmission - Rearend 3 08-01-2011 08:36 PM
Ford Falcon??????? LivenInTheFastLane Engine 14 03-06-2008 12:34 PM
63 ford falcon van quite a few?? FATHER CHUCK Suspension - Brakes - Steering 15 02-07-2005 02:53 AM
Ford Falcon ksm Hotrodders' Lounge 5 01-07-2003 05:04 PM
84 AOD IN 60 FORD FALCON topend1 Transmission - Rearend 5 12-03-2002 08:20 AM
