I would say you're right - that it's a gas thread. But, I've never heard it described that way. It's a tapered thread used to seal gases and fluids.
Look at column 3 in this link... <a href="http://www.plumbingsupply.com/pipethreadsizing.html" target="_blank">pipe threads</a> |
NPT stand for National Pipe and the "T" stands for thread and is tapered. NPS is National Pipe Straight. The size will be determined on the tap. Which for most smaller applications are around 1/4" or 1/8" NPT. Although a 1/4" and 1/8" is considerably larger than 1/4" and 1/8" respectively. The taper is so the tighter you turn it the tighter it seals. Check these sites.
www.ind-supply.com/threads.html <a href="http://ourworld.compuserve.com/homepages/MJVanVoorhis/T103.htm]http://ourworld.compuserve.com/homepages/MJVanVoorhis/T103.htm[/URL] Hope this helps you out. Kevin |
As Kevin said, the 3/8" NPT is larger than regular 3/8" tap. Pipe sizes are from the Inside measurement of the pipe, not outside as with bolts. I thought that usually the threads going into the body of the carb are usually straight , not tapered. Usually they use different types of fittings.
| Recent General Rodding Tech posts with photos |
