3.8L Supercharged V-6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 05:15 PM
Question 3.8L Supercharged V-6
I'm really glad I found this page...
I blew up my 3.1L V-6 in my '90 Chevy Z24. I've really been itching to drop in a punched out 3.8 (to 4.2) Supercharged V-6. Will the SC 6 from the newer Pontiac Grand Am's work? I found an older 3.8 from a Buick and planned on rebuilding that. Any advice?
Old 01-14-2003, 06:11 PM
Post
first of all 3.8 will not go where a 3.1 is at. engine bay not large enought to swap engine and trany. not to mentuiion the dif. in engine controls.lots of luck <img src="graemlins/evil.gif" border="0" alt="[evil]" />
Old 01-14-2003, 07:45 PM
Post
Welllllll. I'm not going to claim to know anything about the GM supercharged 3.8. What I can tell you about is what Ford did. Assuming that you can overcome the obstacles stated by toymobile, here are some things to keep in mind. Ford ran an 8.2:1 compression ratio on the early T-Birds and later upgraded to 8.5:1. Ford deemed it neccessary to run an intercooler to lower intake charge temps, although it appears that they ran more boost than the GM setups. The stock crank was forged vs. cast for the n/a version. The block itself was upgraded over the n/a block. The heads for the SC version are surprisingly identical to the n/a units with regards to port design and combustion chamber. You will need larger injectors (stock Fords were 30 lb/hr on the early models and 36 lb/hr on the later models). You will probably need a larger fuel pump to handle the increased demand. You will need to seriously upgrade your cooling system to handle the increased power. Obviously the computer would need to be changed as well. All that said, your best bet would probably be to find a wrecked late model GTP or Regal GS and swap everything over from that car to yours. Like I said I do not know what GM specifically did(if anything) to upgrade the 3.8 to run boost, but I don't think I would take the chance and just rebuild an older unit.
Old 01-15-2003, 12:31 AM
Question
Engine bay not large enough? I know of a guy that runs a 3.8 Turbo in his second gen Z24 and the largest the second gens ever came stock with was a 3.1 Turbo... the blocks are supposed to be similar in size and the 3.8 compatible with the stock Muncie 5-spd tranny. Maybe I can kiss the Supercharger goodbye and just go with Turbo? Would NOS be compatible with a Turbo or could I boost the power even more with cold air induction? I'm trying to get as much punch put of my Z without having to do any serious tweaking to the body... <img src="graemlins/sweat.gif" border="0" alt="[sweat]" />
Old 01-15-2003, 02:44 AM
deuce_454's Avatar
Post
nos is compatible with turbo, but is rarely used as the turbo has to be designed for the exhaust flow and the exhaust flow increases with NOS, makeing the spool up time off the NOS unacceptabilly high, but with turbo the sky is the limit when it comes to horespower. formula one ran 50 pounds of boost and churned 1200 HP from a 91 cubic inch motor (1,5L), in the real world a GN t-type with 500 ponies is not uncommon now a days
so the only thing you can use NOS for is a sort of antilag system where the nos is turned on at full throttle when boost is lower than your set level and therebuy removeing the lag as the NOS will provide the kick before the turbo sools up.
and if you can put a 350 in a fiero (also a 3.1), then you certainly can fit a 3.8 in your Z24, you might need a shoehorn and lots o dinneros, but everything is possible
[ January 15, 2003: Message edited by: deuce_454 ]</p>
