3-bolt chevy starter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 07:00 PM
somethin4nothin's Avatar
I was told that Chevrolet made a starter that allows three starter bolts to hold the starter to the block. Only two that I know of are the staggered, and straight across patterns.
If there is such a starter, Would anyone happen to know what vehicle(year,mod) it was found in?
Old 05-15-2006, 07:11 PM
poncho62's Avatar
Wiki Edits: 5
I believe that they came on some big block trucks.
Old 05-15-2006, 07:17 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I'm not sure and I can't remember, but I think some old 283 's may have had them also..I seem to remember something like that.
Anyway, It's another place to look..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-15-2006, 07:41 PM
Thanks for the fast response!
I'm looking for some added support on my 350.
I had the block break off on the outer mounting hole (ear). I have just one small piece of the block where it broke, not enough for brazing. There's maybe an inch of threads left, and all else has failed so I'm going for the last chance before I buy another bolck.
While looking for someone to pull off a miracle weld, someone told me about this starter and how it would help to have that other bolt assist with the load.
I'm going to attach a pic if poss.
Thik J.B. could help me in any way?
Old 05-15-2006, 08:22 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Is the block out of the car?
You should be able to get the casting welded back together, but if it broke across the bolt hole, that will have to be filled then drilled and tapped to accommodate the starter bolt.
JB weld , I doubt is up to the task of holding that amount of torque..
The Hi performance mini starters have 4 holes in the mount..you might (if you have enough block left) Be able to drill and tap a mount hole for the middle hole on the mini starter..I don't know how much you have left, but it's worth a look.
Note the four holes..
Doc
Innovations
chevy 350 starter problems!!! zipfactor Engine 19 09-24-2008 09:01 AM
chevy lug bolt size? KNanthrup Transmission - Rearend 4 08-27-2005 10:41 PM
Chevy starter clearance longt Engine 4 08-09-2005 08:10 AM
Early Chevy Starter skiffer Engine 2 10-18-2004 08:23 AM
chevy starter, quick q- killerformula Electrical 2 07-01-2004 11:05 AM
