3 bolt holes for torque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2003, 06:54 PM
A mechanic told me that if the bolt holes for the flex plate are "Long Gated " or "Eggshaped" it could make the crank vibrate and knock. He said it is common for GM flexplates.
Any opinions?????
Old 09-19-2003, 07:04 PM
Jmark's Avatar
All kinds of mis-diagnosed engine problems have actually ended beening loose converter bolts. Sometimes it sounds like a rod knocking, bad mains, rattleing noises, vibrations. If the bolts got loose, the holes will end up egg shaped. Best thing to do is replace the flex plate and bolts, but I've been known to get new bolts at AutoZone and put some locktite on them and nail them down good. At least it worked on our old Chevy impala for quite some time. LOL
