3 core radiator? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2009, 06:51 PM
80 SS El Camino
3 core radiator?
I posted this same thread on another forum, I'm not trying to disrespect anyone but the more opinions I get the better for me and my motor.
I really have no idea how to tell a 1 core from a 3 core. After looking hard at the radiator I have, I *think* it might be a 3 core. The whole core width is 1 7/8" and there are what look like 3 different tubes on the inside. Anyway, here is a photo, can anyone confirm or deny?
Thanks
Old 04-30-2009, 06:55 PM
Thanks
Yep that's what it twere.
Bogie
Old 04-30-2009, 06:57 PM
ericnova72's Avatar
More for Less Racer
Yes, that is what "3-core" or "3-row core" refers to. Easy to tell just by removing the cap and looking inside the tank at how many rows wide the core is.
Old 04-30-2009, 07:04 PM
80 SS El Camino
Awesome, thanks guys!
I was worried. It came out of an El Camino with a 305 but my guess is at some point the previous owner put a better one in when he put the crate 350 in it. Now I know it should handle the stroker going in very soon.
Darrin
Old 04-30-2009, 07:10 PM
Darrin
I don't know if you should go off the deep end yet. It's ability to handle a stroker bigger than a 350 will depend on how well it flows which will have something to do with how clear the tubes are. It would be good to get it checked out by a shop that knows what they're doing as crud and corrosion collect in the tubes. Chemical cleaners are not very good, if it's cruddy it needs to have the tanks removed and the tubes rodded to remove debris. This is a lot cheaper than replacing a toasted motor 'cause you assumed the radiator was up to the task. It happens a lot.
Bogie
Old 04-30-2009, 07:19 PM
80 SS El Camino
Good advice bogie.... will do.
Thanks
Old 04-30-2009, 09:51 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If you ever have a radiator where yo can't see the tubes from outside, just open the cap and look down in the tank. Three rows of openings = a three core radiator
Radiator question, 1 core or 2 core, which is better? 4speed57 Engine 6 04-17-2010 07:28 AM
radiator core support bushing 65 el camino defilade Engine 7 12-24-2008 09:12 PM
Shorten radiator core? rod kent Engine 2 11-18-2008 06:08 PM
Overheating issues... SeeMy355 Engine 32 08-17-2008 02:47 PM
seal - radiator to core support? Mad_Max Engine 1 05-02-2008 04:07 PM
