3-D Rhino ,Render before building. - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Off-Topic
Old 06-18-2011, 08:20 PM
General Martok's Avatar
The render I have is from class ,I made everything in it ,the lighting the color
shades positions.The New Rhino has a Marine Rhino to make hulls of ships,
to see the fluid flow around a hull,or the air flow around a car maybe.
The PDF books are a must and have to walk threw alot to get the hang of it,The
newer version has alot of things that Im reading up on,still learning.One guy
rendered his 79 short bed Dodge and did all the frame work before building it .
Name:	hamman_chess render.jpg
ID:	56157   Click image for larger version
How do I remove Rhino Lining? cyclopsblown34 Body - Exterior 4 03-12-2009 02:38 PM
another rhino liner thread jesse01 Body - Exterior 4 11-09-2005 03:42 PM
Colorado Classic (artistic render) truckshc Hotrodders' Lounge 27 05-30-2005 08:19 AM
Rhino Liner? Capt. Camaro Body - Exterior 7 09-16-2003 08:03 PM
Rhino Liner Jag Daddy Body - Exterior 4 08-06-2003 09:09 PM
