3 deuces, ? adjust center carb needle valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2007, 05:12 PM
55 chevy rebuild's Avatar
I have a 327 with 3 deuces.
I run on the center carb, the front and back kick in when "needed"
On the center carb there are 2 screw needle adjustments...What is the best way to make sure that these are set correctly?
Thanks for the help.
Old 02-28-2007, 05:34 PM
Cobra Pilot
I ran a 283 with 2 Carter 4bbls, and found that by using a vacuum gauge I could get the best tuning results. Just find a vacuum port on the carb, or intake manifold, and slowly adjust to you get the highest reading, take time to let the engine stabilize between adjustments.
Everett.
Old 02-28-2007, 07:00 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
Exactly what Everett said. Just make sure to use a full time vacuum source and make sure the engine is at operating temperature.
Barry
Old 02-28-2007, 07:32 PM
Von MoPar's Avatar
I have three 94 3 bolt hollies on an offenhauser intake on a 241 dodge hemi using a progressive linkage system, middle carb for cruising then the front & back carb come in when using more throttle, i have been told to take out the power valves on the front & back carb to avoid the bog down when flat out?
Carb rebuild - won't start now. Please help? joe99 Engine 6 11-30-2011 03:04 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Adjust Edelbrock Carb bezmanianm Hotrodding Basics 9 06-15-2004 04:09 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 01:10 PM
PVC valves and carb ???? HemmiGremmie Engine 3 10-16-2003 04:18 PM
