3 dueces problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2008, 09:17 PM
Key's Avatar
Key Key is offline
Novice Hot Rodder
3 dueces problems
I keep having trouble with power valvues swelling up and then sticking. On my third valvue in the center carb. Any one else ever encountered this problem? Engine is a chevy 327 with Rochester 2GC carbs. thanks, rvk
Old 04-20-2008, 09:20 PM
Jmark's Avatar
What kind of fuel are you running? MTBE can be hard on rubber parts if it's in a high enough concentration. We get 20% in the winter here in Arizona and so far so good on my engines.
What exactally is swelling and sticking? I don't recall any rubber parts in a 2gc enrichment valve or actuator. The valve is brass and the actuator is metal in the carb bore with a spring. I'm cornfused! LOL
Mark
Old 04-21-2008, 05:41 AM
Last journal entry: A few ongoing projects
".......What exactally is swelling and sticking? I don't recall any rubber parts in a 2gc enrichment valve or actuator. The valve is brass and the actuator is metal in the carb bore with a spring. I'm cornfused! LOL ....."
Same here
Old 04-21-2008, 07:23 AM
Jmark's Avatar
Maybe he means the accelerator pump? That's about the only rubber piece on the carb! LOL If that is happening, there are better pumps on the market. The newest one is blue nitrile and more resistant to ethenol and toxic crap.
Mark
Old 04-21-2008, 07:43 AM
Key's Avatar
Key Key is offline
Novice Hot Rodder
Accelerator pump
You are right - sorry for the confusion. I was talking about the accelerator pump(s).
Now my mechanic says he doesn't think it is the accelerator pump this time it is simply an idle problem. Apparently the cam is so radical (or so he tells me -my engine builder disagrees) that the engine continues to run (even after the engine is turned off). If we idle it down any more, the engine dies in gear while at red lights. Bad situation. Solutions? rvk
Old 04-21-2008, 08:18 AM
NAIRB's Avatar
Rig up a fast idle soenoid that you will disengage when the ignition is off.
383 stroker problems and ways to fix them leftoverchrisac Engine 15 02-06-2009 05:36 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 06:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
