3 inch exhaust looking for back pressure? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2013, 08:29 AM
I currently have 3 inch straight pipes on my truck, has a small block 350 with mild cam. I love the sound but i feel like it needs some back pressure. Seems as if since i have installed the straight pipes it has taking away some horsepower from the truck. Just wanted to see if anyone had any ideas of what i could do without affecting the sound that it has now to much because a muffler will quiet it down more than i would like. One of my buddys mentioned high flow cats??? Thanks I appreciate any feedback, open to all ideas
Old 04-16-2013, 10:52 AM
I'm struggling with the concept that you need backpressure to increase HP. If that were true, Top Fuel cars would have mufflers.
Now, if the increased flow of your exhaust system is causing the carb to run lean, that WILL cause a power loss. Rejet the carb.
The Following User Says Thank You to joe_padavano For This Useful Post:
techinspector1 (04-16-2013)
Old 04-16-2013, 11:11 AM
spinn's Avatar
I have seen where a large exhaust negatively affects the performance. It was on a stock s10 4.3L v6. They were hot rodding it, and went exhaust manifold back. There was a lot going on, but performance was worse.
A good way to determine if you have excessive backpressure, is to take a reading from in front of the mufflers. A Boost gauge stuck in the o2 bung will work fine. Any reading above 2 1/2 psi is excessive and could be costing some power. You might have to put a bung in. It can be used for o2 sensor tuning later.
Old 04-16-2013, 03:24 PM
Banned
back pressure is NOT a good thing. Sometimes having too large of a pipe will cause problems from inadequate velocity though, adding back pressure will make the problem worse- not fix it. It could also be that your tuning needs to be tweaked a little after the exhaust change too.
For a stock 350 with just a mild cam a single 3" is about right.
Old 04-16-2013, 07:27 PM
Banned
sounds like he has 3" duals, as he says pipe(s)
Old 04-16-2013, 07:34 PM
techinspector1's Avatar
Wiki Edits: 326
Common sense to the fore Joe, thanks for that.
Old 04-16-2013, 08:49 PM
vinniekq2's Avatar
headers and sometimes collector extensions,any more back pressure will not add power.
use a x or H pipe and you can buy super short mufflers,just enough to take a little off the top.
check my tread for a moderate 3 inch system,and many other members also posted their cars making noise
land shark,painted jester and a few you tube postings,quite a few actually
2.5 into 2 inch exhaust runn141 Engine 3 07-15-2010 01:19 PM
3inch or 2 inch exhaust winko33 Engine 6 08-20-2009 11:29 AM
exhaust back pressure? desaray79chevy350v8 Engine 8 11-18-2008 06:57 AM
2 1/2 inch exhaust with 3 inch mufflers? newchevyman Engine 9 05-11-2006 01:37 PM
Checking exhaust back pressure with a vacuum gauge? Jag Daddy Engine 2 04-15-2004 09:57 PM
