3 manual speed gearbox on a flathead: which bellhousing can i adapt? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2008, 05:03 PM
Hi every body,
my engine is a flathead Mercury 1CM 1952.
i have found this 3 manual speed gearbox in a french swaapmeet, which is for me a standard Ford 1953. she came from a Ford mainlane with a 6 cylinder I block. (so i must change the bellhousing show on the picture to find a flathead bellhousing).
Some one can tell if i have right about the type of gearbox and where find the name and information about it on the net?
can i adapt a floor shifter on it?
what flathead car bellhousing can i adapt (pictures are welcome) ?
thanks in advance for your answer
sincerelly
JPhi
Old 03-10-2008, 06:42 PM
justold's Avatar
You have the correct transmission , that unit will fit 1952 to 1956 ford or mercury without any modification there are some internal differences between the years . You will need a ford car 1949 to 1953 or mercury 1952 or 1953 flat head V8 housing , these are easy to spot as they are pressed steel rather than cast iron .
Old 03-13-2008, 03:54 PM
ok for the 49 53 bellhousing, i see the part.
about the gearbox, can i adapt a floor shifter? i have found on the net that the original mount is a column front shifter, but aftermarket parts dealers speak about floor shifter possibility on this vintage trans . thanks in advance to give me information about.
Ford Flathead Six Speed Equipment DJD Engine 3 12-14-2009 06:16 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
74 Ford 4 Speed Manual... 59Fairlane Transmission - Rearend 2 12-30-2002 09:34 AM
5 speed to a Flathead? Barz51 Transmission - Rearend 3 11-07-2002 04:49 PM
4 speed manual transmission beetle9 Transmission - Rearend 4 10-10-2002 04:46 AM
