Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3 oil pressure switches?
Old 05-23-2011, 09:19 AM
joe_padavano joe_padavano is offline
You don't need three switches. You can combine the oil idiot light and the fuel pump safety switch by using a Standard Motor Products PS64 sender. This sender has three terminals. The center terminal goes to the idiot light and the outer two terminals are connected together when there is oil pressure to run the fuel pump.
