Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 3 phase and 1 phase
Old 02-06-2009, 02:28 PM
jaguarxk120 jaguarxk120 is offline
What you need is the print from the welder you are buying and the print from the same model in single phase. Then you can compare the two, many times the part numbers are there to help you along.
Can you buy this welder and trade it in on the model you want?
Good Luck
