3 Piece hood Fitted - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-11-2006, 05:02 AM
Dutchman's Avatar
Old Salt
3 Piece hood Fitted
Well, with lots or procrastination, then time and then lots of patience I finally fitted the 3 piece hood. Many said that this would be "fun" to get done. It was a challenge, however, things worked out well.
Still learning and enjoying this immensely.
Dutch
Old 11-11-2006, 05:30 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Looks good Dutch! Another fine hot rod in the works!
Old 11-11-2006, 08:25 AM
302 Z28's Avatar
That looks like a better fit than the first time I tried to do my 4 piece hood on my 34. Did you have to trim it any? Looks like your rod is coming along nicely Dutch.
Got my wheels and tires in a few weeks ago for mine, also the Tea's seat will be here shortly .
Vince
Old 11-11-2006, 09:30 AM
Dutchman's Avatar
Old Salt
Thanks S10Fan, How ya doing on the black side of the river?
Vince, I had to fit and grind down portions of the rear top due to excess. I took off some material and ground the rest to keep as much as an even line down the rear side pieces. I also had to apply a little bend in the side panels to concur with the car body. On the front of the hood, I notched it to fit like a 34 and had to grind down a little on the hoods corners to fit the concur of the grille.
I welded 2 supports to the lower insides of the side pieces that attach to pins inserted through the fenders and used a Carolina custom 3-pc hood hinge kit.
Dutch
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
