3 point seat belts for 1966 Chev PU - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2002, 09:21 PM
Post 3 point seat belts for 1966 Chev PU
I had a long crawl through a local wreckers looking for some 3pt seatbelts that would fit in my truck no luck with Chevy S-10 (4" too short if I want to grow a belly) or full size newer truck stuff (8" inch retractor/cover unit) - The flange on the gas tank behind my seat only allows 4" clearance for the Seat belt retractor on the driver side and the floor pan slopes towards the door so can't be a version that sits perfectly flat to operate. Does anyone know of a good solution?
Thanks in advance.
Bert Annear
Old 10-19-2002, 07:45 AM
Post
HI BANNEAR,I had this with my 43 chev truck,i just bolted + welded a length of steel bar, 3" wide by however long to clear the fuel tank,drilled then bolted my 2 centre straps to that, CHEERS philPKP
