3 spd manu. trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 01:12 PM
Last journal entry: done as of 9/10/08
3 spd manu. trans
can someone please tell me how much of a problem it is to rebuild a 3 spd standard trans.
it is for a 66 bronco
thank you for the help
Old 10-29-2011, 04:16 PM
LATECH's Avatar
That one should be an easy one if you are a first timer at it.
You will want to ID what type of trans you have, probably a type 9.
Then you want to make a list of all the trouble it is having so as to help you when getting parts.
Does it make noise? when doesit make noise?does it go into gear hard? which gears does in go into hard. Does it grind when shifting? etc etc etc.
Also you need to look the clutch over well, and if replacing plan on resurfacing the flywheel, highly recommended for smooth action. NAPA can do that for you.
Be sure when tightening down the clutch cover assembly ( sometimes called pressure plate) that you tighten each bolt a turn at a time going around the cover assembly, one at a time untill you get them tightend lightly, then finish by torquing to spec.Also replacing the pilot bearing.very necessary.
I know it sounds like a lot, but it is not.
Get started and keep your post going and guys will jump in to help...no dout.
TNSmith, crosley and a few others are REAL good at transmission stuff, so you are where you need to be.
Old 10-29-2011, 08:00 PM
3spd for trans
remove the cluster shaft 1st,let it fall to botem of the case(this is after tailshaft housing is removedthe rest is easy.the main need is a dummey cluster shaft which is the same diamtr. butis the identical length of clustrand thrust washers.this simplifyes ***,you greas the inside of the cluster and install the needel rollers,when all in place you gently inst the home made short shaft.tou instthe cluster first and leave it on the bottem until top shaft is assem and in place.cliff
Old 10-30-2011, 03:59 AM
thank you for all the reply's i will be starting on this project soon, i just removed the trans and bell-housing,transfer case from a Donner.
i am trying to replace the auto. transmission that is in the 66 bronco with the std.tran.
looks like a good winter project
again thank you for the help and i will be back looking for more i am sure.
Old 10-31-2011, 11:38 AM
ok i pulled the transfer case of the end of the adapter and found the needle barrings.
how many are there ? and how do you put the adapter shaft back in to the transfer case? is there a easy way?
and another question is the forward leaver on the 3 spd trany is that low-2-3?
and is it supposed to be so hard to shift?
thank you the help
trans swap, 400 trans in 83 elcamino? renagade Transmission - Rearend 2 10-07-2011 09:45 AM
1992 gmc trans shot, will 1986 trans fit? Jamesace Transmission - Rearend 4 05-06-2010 02:42 AM
Synthetic Trans Fluid Mixed With Regular Trans Fluid smokey626 Transmission - Rearend 1 06-14-2009 01:33 PM
help with trans Minace21 Transmission - Rearend 13 02-28-2008 09:27 AM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
