3-Speed on Column to 700R4..questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2008, 01:27 PM
Chim's Avatar
I have a 63 impala with a 235 straight 6 and a 3 speed manual on the column. I am wanting to swap to a 700r4. I will be keeping the straight six for a while longer but want to do the trans now. I am going to be getting an auto column so I dont have to bolt a shifter to the floor. I want it to look stock. What sort of problems will I have.. I know I will have to get a flexplate, linkage to tranny, drive line length, and output shaft..
questions..
1. will my crossmember work in factory location? Will factory crossmember work?
2. what size tranny cooler will i need..
3. will I run into kick down or vacuum problems with only having a rochester one barrel carb?
Any other info would be greatly appreciated!
Old 01-11-2008, 02:04 PM
Jmark's Avatar
Not sure on some of your questions BUT, you will need to fabricate the TV cable bracket on the carb. Not going to be easy but can be done. The TV cable (NOT to be confused with a kickdown cable) MUST be set properly so you don't fry the trans first time out. There is no vacuum connection on the 700.
Mark
Old 01-11-2008, 07:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
questions..
Are you sure you have a 235 cid engine? the old 235 engine (as I recall) did not have the common chevy bolt pattern bell housing .
A 230 cid inline 6 engine does have the common chevy bell housing bolt pattern.
Old 01-13-2008, 08:45 PM
A '63 should have a 230. '62 was the last year for the 235 in passenger cars.
Old 01-13-2008, 09:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
kinda my line of thinking
transmission column linkage- 700r4 to a t-350 frank88chevy Transmission - Rearend 1 01-02-2008 12:27 PM
c10 - th350 to 700r4 swap column shift fixer uper Transmission - Rearend 6 12-05-2007 04:04 PM
84 Chevy truck 700R4 questions ChevyJim Transmission - Rearend 4 12-10-2006 09:43 AM
GM Column Wiring - Help Please Centerline Electrical 1 04-15-2005 06:29 PM
console column to floor column questions LoudMalibu Interior 1 04-24-2003 07:56 PM
