3 speed manual on column - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2014, 09:23 PM
rambler454's Avatar
Last journal entry: 1968 c-10
Im building a 68 chevy truck with the small block i pulled out of my race car.i had to run stall in my car but im my trucks manual.are 3 speeds any good? Im not racing it but i might wanna show off. Every once in awhile.do they hold up?
Old 01-31-2014, 07:30 AM
Last journal entry: Still running strong
Three on the tree, that was the first manual shift I drove, a hand me down 65 Olds station wagon with three on the tree. It will not shift fast at all,also has a long throw between gears. I was as happy as a fly on dog sheet to have a car to drive to high school, but it gets real old after a while. Maybe a first gear burn out but it takes along time to get to second.
Old 01-31-2014, 07:40 AM
My old man and his buddies had a rotating cast of 3spd muncies and saginaws; break em on friday or saturday night, swap em out Sunday morning to go to work Monday. Fine with a mild street car on street rubber. Lots of roundy round guys still use the Saginaw, but they're not doing holeshots and burnouts. Its definitely a grenade, its up to you whether or not you pull the pin. I definitely wouldn't hammer on it real far from home LOL
Old 01-31-2014, 08:47 AM
Wiki Edits: 27
Gm T 85
GM used a few Borg warner T 85 3 speeds in pickups. The T 85 was the base transmission that was redesigned to the Famous T 10 4 speeds, the internals are the same size strength but the T 85 doesn't have a synchro on first gear. Gm also used a few Ford 3 speed top loader that had a synchro first gear, I think only in pontiacs ( late 64) . , same base trans as the Ford top loader 4 speed. . those transmisions are stronger than normal Gm 3 speeds put hard to find
more info from the HAMB
I've seen non O/D T 85s in mid '60s Chevys, and it was a HD transmission option for Pontiac from '58-'64. I also had a T-85 with Chevy bolt pattern and a really short tailstock from a late '60s van.
Old 02-01-2014, 07:33 AM
DeathRattle's Avatar
Some Punk Kid
Im not sure exactly which model 3 speed I had in my first truck, but it had a really low first gear. May play into your rear gear choice or at least something to investigate/consider. Truck had a 2.75 rear and it worked nicely as I could take off/creep with no throttle in some situations. And as previously mentioned the shifting time is not what youd call expedient haha
Old 02-01-2014, 01:05 PM
rambler454's Avatar
Sounds good.i didnt want to at first but i may go automatic.thanks guys
Old 02-01-2014, 01:40 PM
How many of you guys remember driving your Chevy with your right hand draped over the shifter to keep it from popping out of third on acceleration?
BB
The Following User Says Thank You to boothboy For This Useful Post:
AutoGear (02-03-2014)
Old 02-01-2014, 02:55 PM
RWENUTS's Avatar
And lots of us remember carrying a spare tranny in the trunk for the inevitable parking lot tranny swap too!!
Old 02-02-2014, 08:37 PM
Flat blade screw driver to unjam the linkage right their by the steering column.
The Following User Says Thank You to dogwater For This Useful Post:
boothboy (02-03-2014)
Old 02-03-2014, 08:38 AM
My Dad was home from college, cruising with some buddies and this dork in a 63 falcon keeps trying to race him. Fine. Next light they go at it and BANG! down goes Dads 3+ OD with Mystery shifter. The falcon chugs off, leaving my dad to swap gearboxes in the parkinglot of a grocery store. He still gets needled about this. 3 days later he bought his first Muncie 4spd LOL
Old 02-03-2014, 10:34 AM
Wiki Edits: 27
Old school trans
I ran a 37 La Salle behind a Ford 352 police interceptor, 050 pistons from the factory 11-1, with 4 11 gears the gear ratios were just right with the 4.11's. Then a Packard OD. synchro on first gears Big, strong, short and heavy, and the packard trans is now in one of my roadsters.
3-Speed on Column to 700R4..questions Chim Transmission - Rearend 4 01-13-2008 09:53 PM
Moving a 3 speed from column to floor allbusiness46 Transmission - Rearend 7 12-04-2006 10:30 PM
4-speed manual i.d babygene41042 Transmission - Rearend 3 01-13-2005 11:50 PM
Manual 4 speed something ManfromKy Transmission - Rearend 7 04-09-2004 02:16 AM
4 speed manual APACHEMAN Transmission - Rearend 5 07-22-2003 04:11 AM
