3 speed transmission on longer trips? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 10:50 AM
I am wondering how my 350th transmission would do on longer trips. I not wanting to across County more like 4 hours at the most. My trans has a shift kit and a stall tongue converter with the 3500 stall. Thanks
Old 04-24-2013, 12:14 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
If it were mine I wouldn't worry about it. Plenty of guys driving all over with these types of setups, even over long distances.
K
Old 04-24-2013, 03:42 PM
RWENUTS's Avatar
I've you're concerned just put on an auxilliary trans cooler. That higher stall will make higher heat.
Old 04-24-2013, 06:48 PM
Beware that if the vehicle has extremely tall rear end gears and is fairly heavy the convertor is never going to get anywhere near lock up. Way back when I was in High school my best friend had a 79 Firebird that had the factory 2.49 gears in it. He put in a 3500 stall convertor in it. It was awfull at cruise. Everyone thought ithe tranny was slipping until you stepped on it.
Old 04-24-2013, 06:54 PM
it has a 3.73 rear gear and it is posi trac.
Old 04-24-2013, 09:32 PM
It's never going to win a gas milage race but unless the cam is really big that's plenty of gear. However unless you really need a 3500 rpm a tighter convertor would be better.
Old 04-24-2013, 10:13 PM
It has a 268h cam and I think it's a roller I didn't built the car so I don't why he did what he did thanks
Old 04-25-2013, 07:37 AM
run an external cooler and maybe drop the pan/ change the fluid and filter if you haven't done so since you've had the car.
1951 Chevy business coupe, replaced the 3 speed with a 4 speed transmission. EricKessel Transmission - Rearend 1 08-08-2011 08:35 PM
Over fill a transmission to last longer? acr Transmission - Rearend 6 01-01-2009 12:09 AM
t5 5 speed transmission PETLOVER Transmission - Rearend 1 03-06-2007 04:45 PM
reliability of sbc w/blower for cross country trips knipper Hotrodders' Lounge 2 11-12-2003 09:07 PM
best road trips helrazr3 Hotrodders' Lounge 17 08-08-2002 02:54 PM
