3 Speed on the Tree ?s - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2011, 08:48 AM
Green Machine 74'
My shifter quit working on my 74 C10 three speed and I don't know why? This is the first 3 on the Tree I've ever had im not sure what goes into them or how to fix them. I pulled the shaft out yesterday so i have everything in sight just don't know what im looking for. Any takers??? I would appreciate the help
Old 06-26-2011, 09:23 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
If you move the shift lever, does the linkage move at the base of the column?
Old 06-26-2011, 09:30 AM
Green Machine 74'
Not at all it left me sitting and had to get out and manually put it in gear. Now that i have it out i kinda figured out how it works but still im not sure what its actaully supposed to do or look like.
Old 06-26-2011, 09:54 AM
aosborn's Avatar
Wiki Edits: 7
More than likely, the upper collar is rotating on the shift tube. There should be some kind of detent or tang that locks the shift collar to the tube, if that is sheared or worn down it will do as you describe.
The lower shift levers should be welded to the shift tube eliminating slippage.
Andy
Old 06-26-2011, 10:38 PM
Green Machine 74'
Can i see this anywhere or is this gonna be inside the column and unvisible?
Old 06-27-2011, 06:39 PM
aosborn's Avatar
Wiki Edits: 7
Inside the upper part of the column. If the upper collar where the shift lever is connected moves, and the lower linkage or the tube doesn't, it is the connection between the upper collar and the tube. You will have to take the column apart to find out what happened.
Andy
Old 06-28-2011, 02:30 AM
willowbilly3's Avatar
Last journal entry: Body mods
You will have to dis-assemble the collumn. Pull the steering wheel, lock ring and the turn signal switch. You will probably be able to see the problem from there.
Old 06-28-2011, 03:31 PM
Green Machine 74'
Ok ill give that a shot and see what happens.
74 Chevy C10 3 Speed on the Tree Problems! RednKim Transmission - Rearend 0 06-25-2011 07:55 PM
Three on the tree Emmet's '63 Transmission - Rearend 3 05-18-2011 06:40 AM
Oak tree your in my way Rob Keller Off-Topic 2 01-15-2006 08:46 AM
3 on the tree mercflathead Transmission - Rearend 3 07-05-2005 08:19 PM
3 on the tree morris4405 Transmission - Rearend 6 12-31-2003 12:45 AM
