3 speed w/overdrive for my flathead - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2005, 08:57 PM
mercflathead's Avatar
FLATHEAD FOR LIFE
I want a 3 speed manual tranny for me flathead as yall know but can i get one with overdrive, or even a 4speed.
Pat
Old 03-13-2005, 05:36 PM
Three speed with overdrive was an available option beginning in 49, I think. Finding one with the controls will be a bit of a challenge. They are controlled with a cable to manually select and deselect and a solenoid to control. Those 6 volt systems were not the most reliable, but 12 volt models can be used with ingenuity.
Trees
Old 03-14-2005, 12:04 AM
aka Duke of URL
Is it going to be floor or column shift? If floor, you can find a 1974 up Toploader 4/S O/D.
Old 03-15-2005, 07:58 AM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
actually I see them old overdrives all the time at the Jefferson WI swap meet. you can still find em...........
-Leo-
Old 03-15-2005, 09:25 AM
If your flathead is a 1948, or older, I believe some 36 to 41 Lincolns had overdrive. And, if your flathead is 1948, or older, get yourself a 3 speed floor shift ford tranny, then take all the gears from a manual shift 36 to 41 (V-12) Lincoln.
These gears - the cluster gear is 26 tooth - will all fit your ford box and you will have a tranny so strong it will crush a rock crusher.
After 1949, overdive was pretty common.
Regards
Know nothing rodder.
Old 03-17-2005, 08:28 AM
Max Keith's Avatar
3 spd OD
A good one for that would be the 3 spd OD used in Ford Pickups and some cars like the Maverick, in the 70's and 80's. It was a modified version of the Ford Toploader 4 speed. It comes in two styles, external and internal linkage, as well as both steel and aluminum casings. What they did was to convert 3rd gear in the 4 speed into an overdrive, and then flip the shift linkage for 3-4 upside down. These are a pretty good transmission, and will stand up to a lot of abuse. They do use a floor shifter, BTW.
You will need an adaptor plate, as it wont bolt up to your stock bellhousing. The shift into overdrive is done manually, there are no electric or vacuum controls on the OD.
Old 03-18-2005, 01:04 AM
Kermitt47's Avatar
If you don't mind some Chevy stuff to make your Ford tough you could look at the 5 speed from the V6 S10 pickups. It can easily handle the torque of the flathead, is cheap and available, has synchros and there are several places to get the trans adaptor. Just a thought.
Old 03-25-2005, 07:29 AM
Max Keith's Avatar
mix and match
What person in their right mind would want to put a weenie GM tranny behind a good engine?
Ford Flathead Six Speed Equipment DJD Engine 3 12-14-2009 06:16 PM
Flathead V8 ?'s " for school project" 51FordDuff General Rodding Tech 4 06-12-2009 02:55 PM
Adapting a 5 speed transmission to a49-53 ford flathead CARMASTER Transmission - Rearend 3 07-16-2003 12:15 PM
5 speed to a Flathead? Barz51 Transmission - Rearend 3 11-07-2002 04:49 PM
Speed Equipment for flathead six DJD Hotrodders' Lounge 1 08-01-2002 10:39 PM
