3 speeds using relays - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2009, 09:20 PM
boris_thespider's Avatar
I have a 4 position switch (off, low, med, high) and a Summit Racing 3 speed heater. I'm not sure of the current capability of the switch. I would like to run all 3 speeds of the blower using relays. I have a bunch of spdt relays on hand. Is there a simple way of doing this? Thanks in advance...
Mike
Old 12-10-2009, 05:46 PM
Hoptup32's Avatar
You can use 16 gauge wire from the switch to the 86 terminals on the relays and also to connect the 85 terminals for ground. Be sure and use 12 gauge wire for the 12v power to the 30 terminals on the relays. Are you using the switch that came with the Summit heater?
Name:	Fan Wiring.jpg
Old 12-10-2009, 07:59 PM
Thanks for the great schematic, Hoptup! I got this heater a while back and I don't think it came with a switch. I ended up with one that looks heavy duty and probably is... but I don't know for sure. So, I thought I would just use the relays and extra wire I already have. Thanks again for the diagram...
Mike
Old 12-10-2009, 09:15 PM
Hoptup32's Avatar
I kind of took for granted that you know to fuse the two 12v wires or run them from an existing fused source. I would use a 30A fuse on the 12v to the #30 terminals on the relays and a 5A or 10A on the 12v to the switch.
I'm with you, I would rather use the relays to feed the power to control the fan. I've had problems with the so called heavy duty fan switches in the past. After disconnecting the wires a few times from the switch, the terminals become slightly loose, then they generate heat because of the poor connections and if you have an aluminum switch knob, it will burn your fingers when you go to turn it off. Ask me how I know! Lesson learned.
Get the heat going, its getting colder everyday you wait!
Old 12-10-2009, 09:37 PM
Yes, I did realize that I needed to put in a couple of fuses. I have the switch going through my fusebox already... but I'll have to pick up a 30 amp. I should probably make that a heavy-duty, inline fuse. By the way, I just noticed that you're from Virginia Beach. Is it getting really cold yet? My wife and I are coming down there for the week between Christmas and New Years. Trying to escape some of the snow and cold that Western New York is famous for...
Mike
Old 12-11-2009, 05:07 PM
Hoptup32's Avatar
Our weather is wacky. Yesterday it was 73* Its 39* right now, at 6pm. It's supposed to be 60* on Tuesday. The weatherman was joking this morning that there is an outside chance that we will have snow on Christmas. But heck, they can't even predict the weather two hours in advance, much less two weeks! It certainly won't be as cold as western NY!
Old 12-11-2009, 09:38 PM
60* sounds fine to me! Today it was 13* and below zero with the wind chill. The only silver lining us is that we didn't get the 3 feet of snow they got south of Buffalo. We're closer to Niagara Falls and we got zero inches of snow
Mike
brake light relays? Cape Cod Bob Electrical 4 05-26-2008 10:57 PM
relays are my new best friend!!!! elcaminodragster Electrical 9 04-22-2008 01:00 AM
Multiple relays needed jjl Electrical 5 10-09-2007 04:58 AM
Help! 1988 Camaro Relays..need Identification boneyard Buick Engine 2 07-08-2005 06:03 PM
Where to Put All The Relays Viet Nam Vette Electrical 11 02-18-2005 12:49 PM
