3 on the tee conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2004, 10:10 PM
New Member
I have a 51 chevy deluxe with a 3 on the tree and I want to convert it either to a floor shift or an automatic.
does anyone know the easiest way or anything about converting it?
I dont know much about trannys.
thanks,
Old 06-16-2004, 10:19 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Well assuming you wanna keep the three speed, I'd imagine the easiest thing to do would be buy a three speed floor shifter, cut a hole in the floor and connect your shift linkage. I'm not an expert so I could be wrong.
Old 06-16-2004, 11:39 PM
Just make sure the shifter will fit the pre-'55 Chevy transmission.
Old 06-17-2004, 09:00 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
And you need to remove the shifter from the column.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
