3 Way Valve for Exhaust System - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2007, 05:05 PM
I am trying to find a vendor that can supply a 3-Way valve to switch from a under car exhaust to a side exhaust on a C2 Corvette.
Several folks on the forum advised me to contact Summit Racing, but Summit offers diverter valves and I would need to install 2 separate valves off of each manifold down pipe and I am fearful of too many valves and the ramification of a valve failure.
I was hoping that maybe someone has knowledge of a vendor who sells a 3 way valve (one inlet with the ability to direct the output to either the side exhaust or the rear exhaust) that has a 12 volt solenoid. A 3way valve would limit the installation to two valves.
Am I asking for something that does not exist?
Thanks in advance for your responses---Mark
Old 08-01-2007, 06:25 PM
techinspector1's Avatar
Wiki Edits: 326
Call Summit and ask if such a thing exists. If they don't know, ask for the phone number of the vendor and call them.
Old 08-01-2007, 11:48 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
H'mmm maybe I am confused here but all I have ever known about is a diverter valve that has an inlet and a gate that directs the exhaust to either the exhaust or the side pipe..we called them cutouts that cut out the flow to the exhaust and diverted it to an outside pipe..
In any case I can only see two one on each side if you have a dual exhaust system..We have had them for years and the old ones used a cable like a lawnmower throttle cable to operate..
Is this something like you are are looking for???
Sam
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
I think you are over thinking your exhauast system. Use a single type valve as shown in the previous thread. Place the valve in your pipe to the side exhaust. When the cutout is opened the exhaust will take the easiest way through your side pipes as they are less constrictive and go through your stock system when it is closed.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 08-02-2007, 06:11 AM
Thanks for your input. I probably am "over engineering" this project and will try the single valve on each exhaust pipe.
Regards--Mark
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Summit Ignition System vs MSD Harley Monster Engine 4 07-22-2007 04:09 PM
When Should one Install Dual Valve Springs on OEM GM BB Auto-Part Engine 7 11-29-2003 05:35 AM
Should I keep my hydro-boost brake system? drlindz Suspension - Brakes - Steering 3 09-11-2003 09:38 PM
question on hardened valve seats stfinney Engine 19 05-06-2003 06:46 AM
