3-wire alternator upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2008, 04:45 PM
I'm upgrading my old externally regulated alternator to a new 3-wire unit and would like to know what to do with the wires that are connected to the old regulator. I've read that I should splice #1 to #3 and #2 to #4, but what do I do with the ends of the wires that were hooked up to the old alternator ( besides the Bat & ground wires)?
Old 06-18-2008, 09:06 PM
31 five window
Last journal entry: grill and rear end
What kind of vehicle and what year?
Old 06-19-2008, 12:27 AM
It's a 67 Chevy C-10.
What I've done is connect the #1 terminal wire to the # 4 wire on the old voltage regulator which goes to the ignition switch and fired that puppy up. The alternator charges and the motor shuts off when I turn the key to off.
Old 06-19-2008, 02:21 AM
malc's Avatar
Living At The Speed Of Life
Here is some helpful information which can be applied to your vehicle.
Old 06-19-2008, 12:37 PM
malc's Avatar
Maybe this can help.
Old 04-21-2009, 01:48 PM
New to the board. Love the wealth of info but cannot find exactly what I am looking for. This post was as close as it gets, but I have a 3 wire externally regulated alternator. Any ideas or leads as to how I hook that bad boy up?
Thanks in advance. And allthough I didnt know him RIP DocVette, you seemed like a very knowledgable man. I wish I could have picked your extensive electrical brain before god decided to take you.
Beau
Ohhh 1962 Impala, 327, OG powerglide. Allready had the 3 wire external regulated alternator on it, but I just replaced it because someone said it was bad. Turns out it is something else since the car still dies if I drive across town and turn it off. If I let it sit for a hour or two it turns right back on, drive it 15 minutes stop to cash a check come out dead. Need any further info to help me along my path please let me know.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
How do I wire a 3 wire alternator when I used to have a 1 wire alternator??? billsbird Electrical 7 09-05-2007 10:01 AM
Starter Problems Jsquier Electrical 5 08-26-2007 06:32 PM
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 02:50 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 05:22 PM
