3 wire oxigen sensors - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2005, 01:07 PM
70bird's Avatar
Smile if you know Jesus
Last journal entry: Waiting for a tranny
I have one wire oxigen sensors after each long tube header, wired to their own guage in the dash. They take a long time to warm up and cool down very fast. I've read somewhere that they have to be 600* to operate correctly. I'd like to switch to the 3 wire, heated O2 sensors.
Lets assume I buy some 3 wire O2 sensors. I assume the three wires are: guage, ground, and heat. Is this a correct assumption? If so, does the heat wire only require a "hot when on" connection? Does the heat wire need to be regulated in any fashon?
Thanks for any info.
Old 04-22-2005, 01:21 PM
NorthStar's Avatar
Sounds like you got it all figured out.
Heater just takes straight 12 volts it doesnt need to be current limited or anything like that. Hot and a ground for the heater element, usually two white wires doesnt matter which is which.
One wire for the sensor. Sensor ground is through the casing & through exhaust manifold.
There are 4 wire sensors from newer vehicles that have a wire for the sensor ground. They cost more though.
Old 04-23-2005, 10:13 PM
70bird's Avatar
Do most O2 sensors have the same thread pattern and bung diameter?
Old 04-24-2005, 10:32 AM
Yes. All that I have seen are M18 x 1.5 metric threads. Even the newer wideband sensors.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
new welding wire oldred Body - Exterior 93 05-07-2009 05:40 PM
Battery problem? evltwin Electrical 11 04-10-2005 07:45 PM
One wire or three wire? Screwy Lewy Electrical 0 06-30-2003 05:33 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 10:59 PM
