Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 05-09-2008, 08:50 PM
william r plise's Avatar
william r plise william r plise is offline
30 coupe
Well now Im bummed. I spent two days wire brushing every crack and cranny, new welds, and every seam then I went and got some PPG dx579 metal cleaner and cleaned every inch of the coupe. according to the guy's at the paint store you are supposed to wash it off with water right away. I did and the dang car rusted on the spot. What the heck. Is this what is supposed to happen? Do I need to clean it again or just epoxy primer right over it? Pops
Old 05-09-2008, 09:29 PM
lets cut it up's Avatar
lets cut it up lets cut it up is offline
re: 30 coupe
I make sure that the metal is sanded good and the n would clean it good with a solvent based precleaner to get any contaminates off and shoot the epoxy. Metal conditioners i feel do more harm than good. JMO Tim
Old 05-09-2008, 09:56 PM
boatbob2 boatbob2 is offline
boatbob2
cleaning metal.....
HI,i always clean the metal (after ive sanded it good) with phosphoric acid (HOME DEPOT) then wire brush off the residue,and apply at least 2 coats of epoxy primer. never had a problem later with rust.
Old 05-10-2008, 05:52 AM
adtkart adtkart is offline
adtkart@aol.com
re: 30 coupe
If the metal is sanded good, cleaned with a water borne wax and grease remover, there is no need for a metal conditioner of any type. As far as I am concerned, they are just a way for the manufacturers to make money. A quality epoxy primer doesn't need metal conditioner applied for it to work.
Aaron
Old 05-10-2008, 07:47 AM
baddbob's Avatar
baddbob baddbob is offline
re: 30 coupe
Usually if there's some flash rusting it will remove easily with just a red/maroon scothcbrite. If you're using any kind of 2K primer Epoxy or any form of DTM urethane or epoxy hybrid the metal will need to be textured will before it's applied. A good 80-180 grit scratch works well. A quality epoxy gets my vote for the sturdiest foundation and anti corrosion primer. Self etch primers don't require any texture. Neither should be applied over a phospheric prepared surface-these metal preps were designed for use under lacquer primer. I do use some phospheric acids (naval Jelly and also a product made by Kleenstrip) to remove corrosion but when I'm done it gets rinsed with water and before priming I sand to clean bare metal. Works for me.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "30 coupe"
filling top 30 coupe william r plise Body - Exterior 1 03-02-2008 08:43 AM
How to proceed 30 U coupe project? 1930u Body - Exterior 15 01-25-2008 10:21 AM
30 ford coupe william r plise Body - Exterior 5 01-13-2008 05:43 AM
30 coupe sheet metal william r plise Body - Exterior 5 12-09-2007 07:41 AM
30 coupe tucker1 Introduce Yourself 1 03-12-2006 05:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
