30 coupe bottoming out - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 12:58 PM
Hey guy's, I have a 30 model A Coupe on duece frame rails and its bottoming out on turns and bumps. to fix Im going to raise the rear body using a 2" spacer and resetting my shocks. I also am running the 40 style rear spring which is shorter than the stock taller rear spring. I was just reading the So-Cal parts catalog and noticed that I should be using a rear pan hard bar to keep the body, frame from lateral movement. My question could this be the reason she's bottoming out? Is this enough shackle movement that would cause it to bottom out? bill
Old 03-10-2013, 02:38 PM
Banned
the panhard bar keeps the rear from going side to side. not up and down. A stiffer coil over shock could help.
Old 03-10-2013, 02:56 PM
model-a's Avatar
Last journal entry: tools
I had that same trouble with my 50 shoebox bill,It all started when I took my front stabilizer bar off.This may be a whole diffrent thing bill I may or may not have help bill.
1937 chevy coupe vs business coupe a70dart General Rodding Tech 14 06-04-2013 02:31 PM
David Vizard's Idea of Almost Bottoming Hyd. ? BUFFALOBILLPATRICK Engine 46 06-24-2010 02:25 PM
Rear shocks bottoming out firestone Suspension - Brakes - Steering 5 08-18-2007 08:55 AM
37 chev coupe 40 pontiac coupe duke mauk Introduce Yourself 2 01-25-2006 12:50 PM
Rockers bottoming out on studs? Siggy_Freud Engine 4 01-31-2005 03:33 PM
