Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 30 coupe brake question?
Old 08-13-2012, 03:28 PM
bill plise bill plise is offline
brake question.
Rwenuts, If the two systems are independent would not a pedal that goes to the floor after a week of sitting be caused by a defective master cylinder. I have a 30 model A coupe 350/350 with manual brakes disc front and drum rear {corvette cyl] . I have a miminal leak at the prop valve at the threads which could be the cause of the rears not pumping up but the fronts should keep pedal up, right? another question is do I really need a proportioning valve to begin with. bill
