Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 02-08-2008, 10:54 PM
william r plise's Avatar
william r plise william r plise is offline
30 coupe metal
help! I just discovered in taking off the moulding around the front of the firewall, rot almost all the way up the side of the cowl just under the molding. Its so bad you can see thru it. So , Im wondering if the roadster side cowl from brookville might work. I know I will have to use it like a cowl repair and cut it but does anyone know if it is the same width and shape as the coupe. they have a complete side cowl panel that I will fork the doe over for if it might work. Pops.
Old 02-09-2008, 06:00 AM
F&J F&J is offline
re: 30 coupe metal
The 2 bodies use the same hood. So, that would mean some of the metal would be the right dimentions....depending on how wide of a strip you cut, back from the front of the cowl side.
The coupes flare out a lot to make more room inside.
I wonder if you can ask around out there locally, there was & are lots of old cut-down Model A's...and one from the desert southwest would be in good shape...cowl, that is. Some get parted out, check ebay too. I'd bet a sedan would work also.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "30 coupe metal"
Metal Fabrication book review. MARTINSR Body - Exterior 7 03-27-2006 11:35 AM
30 coupe tucker1 Introduce Yourself 1 03-12-2006 05:57 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
30 Ford coupe..... SJFast Hotrodders' Lounge 0 09-27-2002 01:47 PM
