This would be a good project for someone with a flow bench and/or an engine dyno. Personally, I think that if it made a useful difference someone would be marketing the 30 degree valves. A quick check in Ferrea and Manley shows no 30 degree valves for the BBC or SBC. BTW, I personally think David Vizard is a legend in his own mind and is seriously over-rated as an engine guru.
tom |
The only gains are in the low lift ranges so that probably explains why Manley and Ferrea don't market them since there probably isn't much low rpm racing going on. I don't know if Vizard is overrated or not but either who.... has anyone done any real world testing? Back ttt. Bob
30 degree valve seat
Bob,
I am currently investigating this scenario. With a mild cam there may be some significant advantages since the crossover point is usually around .300"-.400" valve lift. What this means is that you may be able to get more power from a stock type motor and maintain decent fuel economy by keeping the stock cam. Working on a set of 305 heads now that will be going on a 327 sometime this summer. If interested, AMC wrote an SAE paper in the early 70's comparing the flow differences between 30 and 45 degree seat angles. Another thing to consider is that the 30 degree seat may help prevent exhaust seat recession on some of the older heads that relied on lead in the fuel. NR-Paul |
Cool! Let us know how the little mouse runs. Using the 305 heads and small combustion chambers you should be able to unshroud the valves and still keep the chamber small. Some of the 262, 267, and 305 heads were only 52cc's I opened up a set of these and ended up with 64 when I was done. Interesting stuff. Bob
Vizard has info on SBC 30* intake seats in this book: http://www.aptfast.com/APT_Parts/Boo.../B-93_info.htm
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| SBC Intake manifold fit - best way? | Limey Simon | Engine | 5 | 01-22-2003 02:19 AM |
| sbc intake | chevypunk | Engine | 1 | 11-30-2002 02:37 PM |
| Weiand SBC Intake 1456 | hotrodron | Engine | 0 | 11-19-2002 05:42 PM |
| adapting early sbc intake manifold to 1987 350 heads | steve curtis | Engine | 1 | 06-13-2002 02:56 AM |
