Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 30 degrees at idle & 38 at 2000+ OK?
Old 07-13-2004, 10:22 AM
coldknock's Avatar
coldknock coldknock is offline
An iron headed 383, 10.25-1 comp, small cam, tight converter and 4100lbs to boot. Even with 4.10 gears it'll ping like a tin can full of ball bearings with 30 degrees of initial timing.
10-12 initial and no more than 36 total would be a good starting point and that's a little on the high side.
Larry
