Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 30 degrees at idle & 38 at 2000+ OK?
Old 07-13-2004, 12:05 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Sometimes with a nasty cam and low compression you may need that much idle, but that is a strange case or a poor combination when it is needed. I think that 20 initial should be plenty if you can get it down there. If it is not hard to crank, it is likely not going to hurt anything to leave it.
Chris
