30 ford coupe front floor - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2010, 10:06 PM
Does anyone have or have seen a project journal on installing a front floor in a 30/31 coupe with a recessed firewall? Im building a 30 ford coup highboy on a So-cal deuce frame. My question would be, how do you inclose the toe board sides and area where the firewall is recessed at the top sides of the toe boards. this thing's got more air leaks than a roadster..
Old 01-14-2010, 12:46 AM
327NUT's Avatar
I'm sending you a pm, a guy I know builds 'em in St. George....
Old 01-15-2010, 12:24 AM
Not a Model A ...
But a 32 Ford 3W photo as a example. Not very difficult to fabricate.
I use poster board to make a pattern and then transfer to metal.
A good welder helps.
30 ford coupe william r plise Body - Exterior 5 01-13-2008 06:43 AM
35 Ford Coupe front clip on 35 Ford truck 35hotrodtodd General Rodding Tech 8 12-27-2007 03:00 PM
30 ford sedan madness??? MustBnuts Introduce Yourself 18 06-25-2007 01:07 PM
Fiberglass Front Clip for 51 Ford P/U sandidande Body - Exterior 10 05-17-2007 08:25 AM
30 ford sedan madness??? MustBnuts Hotrodding Basics 1 08-08-2006 06:44 PM
