30 Model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 10:00 AM
30 Model A
i wonder if any one can tell me if a 1930 Ford Model A frame is solid enough to handle a 300 horse engine. I know that Ford beefed up their frames in the early 1930 s but I don't know the exact year. I have a line on a 30 but I don't want to go through beefing up the frame, so if any one can give me this info it will be appreciated. Thanks. NO REPLY IS NECCESSARY AS I FOUND ALL THE INFO I NEED IN THE DATA BASE.
Old 07-09-2012, 02:26 PM
30 Model A
I curently run a 270 horse 283 with a 4 spd in my 28 coupe and I have no problem with the frame. Before I put the motor in I boxed the frame rails on both sides front to rear w/1/8 in plate. I also installed a removablle cross member with the 4 speed which strengths the rails a lot.
So to sum it up YES the rails will take 300 HP plus.
Jerry
Early model roller cam in a later model motor? ricksgtx Engine 6 09-05-2010 04:04 PM
early model vs. late model 350 blocks quincysmith Engine 11 08-15-2007 11:12 AM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
Model A, Model T Gas Tank?? my51chevy Body - Exterior 4 11-13-2005 12:35 PM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
