30 spline differential axle or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2010, 06:05 PM
how do i figure out if my rear end is a 30 spline or 28 spline?
Old 10-01-2010, 06:10 PM
ericnova72's Avatar
More for Less Racer
The obvious...pull an axle and count the splines .
First off, what rear axle?? 12-bolts are all 30 spline stock, 8.5" 10-bolt can be either depending on year. What year is it?? You can tell by year if it hasn't been swapped.
Old 10-01-2010, 06:14 PM
big gear head's Avatar
High Performance Rear Ends
If this is the '71 Chevy truck 12 bolt then it's got 30 spline axles and a 30 spline pinion.
Old 10-01-2010, 07:38 PM
ya its my 71 truck rear end and ya its a 12 bolt the gears are 41/11 (3.73) gearing also im thinkin its a GM 8.875
Old 10-01-2010, 09:45 PM
You are correct, it is a 8.875 (8 7/8) Chevy 12 bolt truck rear end.
Problem w/ 8.5" C-clip axle joe_padavano Transmission - Rearend 17 05-15-2009 11:48 AM
32 Ford rear axle setback; wrong info? F&J General Rodding Tech 17 07-04-2008 07:40 AM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
Chevelle 12 bolt axle spline count JamesRS Transmission - Rearend 4 10-23-2004 10:21 PM
30 spline posi unit..what axles? 383MontecarloSS Transmission - Rearend 3 03-09-2004 12:36 PM
