300 I-6 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2008, 08:53 AM
Last journal entry: ls1
300 I-6
I got a 1983 ford I-6 with the electronic ignition. Does anyone know how to wire it up(hot wire) it without the brain box?
Old 06-10-2008, 09:13 AM
Wiki Edits: 31
you need some sort of a brain box to trigger it, it is a Duraspark II and uses a magnetic trigger which will not work on it's own.. GM HEI can be used, and you just zip tie the modual to an old computer heat sinc, with a little thermo compound on the back.. just wire it like this
Old 06-18-2008, 06:57 PM
didnt work
I tried that set up above, it didn't work. I have three outlet wires from the distributor I thought the third(black w/white stripe) was a tach output? Maybe not, any other ideas?
Old 06-18-2008, 07:55 PM
Wiki Edits: 31
the third wire is an unused wire when using the GM HEI..
this is the only way to wire it w/o the DS box.. unless you do what I did and run an MSD system... my '66 200 is running a DSII, fired with a MSD 6 BTM as the engine is turbocharged
Ford 300 six cylinder custom head Chris Kemp Engine 19 01-26-2016 09:56 PM
300 I6 Maverick? 1cleanmav! Engine 7 09-19-2007 11:00 AM
Got this carb in trade, only 300 miles on it.... he says. killerformula Hotrodders' Lounge 7 10-19-2004 05:42 PM
everything i should know about the 300 aceshigh505 Engine 11 09-07-2003 05:08 PM
reaching the great 300 mark camino_man Engine 5 05-14-2003 03:33 PM
