300h.p. 350sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2003, 08:35 PM
Coleman396's Avatar
300h.p. 350sbc
Hello Chevy fans. I just stumbled across a 1969 350ci from a Chevy Caprice. It is a 300 horse model! Can anyone tell me the specs for this engine. I believe the heads are the 041 castings and according to the owner it has a steel forged crank. Does this sound right? I am also wondering what the factory compression ratio would be. Is this a valuable engine? It is all stock and all complete from the pan to the air cleaner. Thanks a bunch!
Old 10-18-2003, 11:23 PM
DoubleVision's Avatar
Quite a good find indeed. these had the 041 castings with 1.94 1.50 valves 64cc chambers, 10:1 compression, a cast iron intake with Quadrajet on the top, and if I remember correctly the one I had came with a cast iron crank, but it`s been so long ago I really can`t recall, look at the cranks parting line, if it`s wide it`s forged, if it`s thin it`s cast. these blocks are also sought after, there somewhat meatier than later blocks.
Old 10-19-2003, 08:29 AM
Coleman396's Avatar
Thanks for the reply Doublevision. I cannot see the crank end yet because the engine is installed partialy anyway.
I think maybe I should just but it and hope for the best. The Mortec site tells me it could be a two or a four bolt main so I guess we will wait and see. Have a great day!
