300HP to the wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2010, 11:20 AM
300HP to the wheels
I would like everyone's opinion on what it would take to build an engine to deliver a true 300HP to the wheels.
The only stipulation is that we are going to be working with a 4" bore chevy block.
The chassis will have a manual trans & lets say 3.73 gears.
Please get as detailed as you would like, the more detailed the better as far as I am concerned.
Old 09-22-2010, 03:21 PM
techinspector1's Avatar
Wiki Edits: 326
I guess the amount of flywheel hp required to deliver 300 to the rear tires will be determined by what conversion factor you use. If you feel the drivetrain will eat up 25% of the flywheel hp, then you would need to build a 400 hp at the flywheel motor (400 times .75 = 300). If you feel the drivetrain would eat up 33% of the flywheel hp, then you would need to build a 450 hp at the flywheel motor (450 times .67 = 301.5).
There are many recipes for building over 400 hp with a 350 (4" bore block) including this one I put together yesterday....
Vortec Engine Help
Here's over 100 dyno-proven combos, most of them 350's....
http://www.ryanscarpage.50megs.com/combos1.html
Old 09-23-2010, 04:47 AM
Thanks for the Response TI1.
I appreciate your input.
Chevy 14" Rally Wheels eocoolj Hotrodding Basics 16 07-03-2010 09:07 PM
beware whiteys wheels Dainleljedal06 Off-Topic 7 08-17-2008 06:48 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Wheels Wheels Wheels chevymastermind Hotrodding Basics 2 02-22-2006 06:18 AM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 09:24 PM
